Rendering Weirdness
MJ007MJ007 Posts: 1,716
edited October 2014 in The Commons
I am attempting to render the sign below, but the further away the object is, the more the sign distorts. Is this normal and if so, is there any way to prevent this from happening? I would like the sign to remain in focus.
-MJ
Post edited by MJ007 on
  • Scott LivingstonScott Livingston Posts: 4,350
    What software and render engine are you using, and what are your render settings? Assuming you are using DS, make sure you don't have Depth of Field turned on, and in the Render Settings pane, try lowering the shading rate. Also, saving as a .png instead of a .jpg may help...
  • MJ007MJ007 Posts: 1,716
    I am using DS2.3 & 3Delight. I dont recall experiencing this before and i got a feeling it is a DOF issue. Im no longer at my workstation, but i just found a tut on DOF so i will work on that this evening.
    Thanks for the tips on the PNG vs JPG. If all else fails, I will try that as well.
    -MJ
  • MattymanxMattymanx Posts: 7,000
    Increase your pixel samples as well. 16 should be more then enough
