Shaping Tub Trouble: my morph is not there
Hello guys! I'm creating morphs for my armor. Everything is fine except the fact that my morphs are not shown in the Shaping Tub. When I look at the products created by the PAs, I see that any piece of clothing, which is selected in the Scene Tub, is also visible in the Shaping Tub. It looks like this: Sandals (or any other name)/Actor/Adjustments. This is how you get access to morphs via Shaping Tub. In my case, however, when I select a piece of armor, the Shaping Tub stays empty. My piece of armor is now shown there. When I click Parameters Tub, I see my morphs there (I saved  them in "Transforms" section). Obviously, I am missing  something.
Should I choose a different option in "Group Path" while creating my morphs? So far I've chosen "General/Transforms" (please look at thhe picture). Nothing better comes to mind. What am I doing wrong? Can you help me?
  • GordigGordig Posts: 10,600
    If you're putting them under transforms, it makes sense that they wouldn't appear under Shaping. I've never used GoZ, so I don't know if you have the option to create a category there, but if you've already added morphs and they're categorized under Transforms, you should go to Transforms and re-categorize them. Click on the gear icon next to your morphs and change the path there.
  • Yes, you need to put the morph in the Acrtor group - and, though this shouldn't be an issue coming from ZBrush via GoZ, make sure the Property Type iss et to Modifier/Shape.
    The problem is I don't know how to put the morph in the Actor group. Please, look at the picture.  I don't see such an option there. How do you put the morph in the Actor group?
    1324 x 1099 - 312K
    Please look at the attached picture. Here is the list of all the available options when I click on the gear icon and try to re-categorize my morphs. What should I chooze?
    1852 x 567 - 341K
  • Eternal ForceEternal Force Posts: 307
    edited September 2021
    I quess the question is: why don't I see Actor group when I select my freshly rigged piece of armour? I cannot put my morphs into Actor group because I don't have Actor group. How can I create it?
    453 x 728 - 88K
    Post edited by Eternal Force on
  • Don't click the arrow to get the list of existing paths, type into the text box (using / as a separator). Actor/Some group/or groups
    Yes!!!! Finally!!! It works! Thank you very much,  Richard! yescheeky
