Eyebrow Remover
I wanted to point out a free new-ish plugin that can be used to remove eyebrows from textures (or other things) if you use Paint.net. It came in handy for me trying to remove eyebrows from the Retro Heroine character.
Install them per the documentation. Open the face texture in Paint.net. Use the lasso select tool to select around the eyebrow. Choose the Effects > Selection > Content Aware Fill. It autostarts, and voila! No more eyebrow!
Worked perfect results first time for me. I assume it can be used for other similar things that you want to be removed.
Hope it helps someone!
Thanks for the heads up...
Haven't used Paint.net before... but it has me curious!
Cheers!
NP, I have used it for years...I think it's very intuitive, and super easy to use. It has less features than something like Photoshop, but it seems to have a good following and a bunch of plugin creators to fill in many of the gaps, like this one.
