Is there a way to do a shaping morph or shaping preset for only the eyes?
JonstarkJonstark Posts: 2,738
edited September 2021 in The Commons
I'm trying to bring Stratus Mcloud (Hiro 3) as a character preset for Genesis1.
I have GenX2, but there's a bug in it that seems to affect H3 and A3 characters, namely it works for the shape of everything else but the eyes, which blow up huge:
It's only a few minutes work with the scaling and translation parameters of each eye to fix it:
But the problem is I don't want to have to do this manually by hand every time I want to dial up this character.  I tried exporting as an .obj to re-import into it's own morph, but apparently GenX2 in this case changed the number of polygons, so I can't just make a full body morph to apply to the whole Genesis figure.  When I try to save my corrected version as a shaping preset, it doesn't seem to read the changes I made to the eyes and I get the shape plus the blown up bug eyes.
Is there a way to save the eye changes I've made so that I can dial the character in with just one (or two) parameter sliders?
Post edited by Jonstark on
  • CHWTCHWT Posts: 1,187
    Did you try saving the post-eye adjustment shape as an obj (base resolution, no subdivision), then loading a new genesis and use morph loader to load the obj as morphs, adjust rigging to shape and ERC freeze, finally saving as a new morph asset?
    Post edited by CHWT on
  • JonstarkJonstark Posts: 2,738
    Let me double check that it was at base resolution...  Pretty sure that's what I did but it's worth a 2nd look to make sure I didn't miss something.
    Ha, that was it.  It was on high resolution.  Dumb mistake on my part, thank you very much!  :)
    You are welcome !
