Headshop 14 imports coming out not right
abelundercity_7fb40cbc22
Something seems to be getting lost in translation when I try to import a face in Headshop 14. Here's an example:
In Headshop things seem to be going smoothly
Once I import into DAZ, things seem to go wrong. Especially when it comes to the lips:
I followed the installation instructions to a T, or at least I think I did. Any help or insight here would be appreciated.
Pls. email tech support at [email protected]. We can set up a skype call/screen share and fix the issue.
Abel, simple problem. Pls. read the manual/troubleshooting to see your answer.
In short, there's a highlight on the lip, which HS takes as open mouth/teeth.
Either retouch highlight before using photo or use different photo.
As fat as the remnant hair, that can also be retouched.
Otherwise you got decent results.
