g8f g8.1f g8m g8.1m
G8 series takes a long time to load, mostly thy don't load I did a test and after 5 hr's gave up. There has to be a reason that I am not able to figure out. After a total reinstall same same.
Any ideas will help I am sure .
Thank you
John
When you load a figure, Daz also has to load every single morph that goes with it and it also has to reconcile any issues that arise from them. If your figure is taking five hours to load, there's probably some issue affecting all your morphs, which means Daz wastes time trying to rectify it for every single property it loads.
Help -> Troubleshooting -> View Log File
If there are errors, they'll be in your log file. Let it run for ten minutes, cancel it, and then review the last few lines to see what's taking so long.
will do
