DS Animate Lite Walk Cycle
Can anyone direct me to a video that show how to fix the Toe Up of figures at the beginning of a walk cycle?
I've been looking for a while and I can't find what I'm looking for.
I'm using DS 4.6 Pro with Animate lite and the M5 figure.
Thanks,
Darren
Have a look here : http://www.daz3d.com/forums/viewreply/231972/
Hope that helps?
It's pretty simple...
Basically, you go into keyframe mode, and then select level 1, where you will make the foot adjustment.
Go to frame one. Now bend the feet down. A new keyframe in that layer will adjust the feet throughout the entire animation. You can scrub the timeline to see the change.
Switch back to "base" level, and come out of keyframe mode.
If the figure has shoes on, move the figure up, then press command-D to move it back to the floor.
Thank you for the tips, I will try them all.
I only have Animate Lite, so I can't do the Sub Tracks.
This would definitely be a good topic for a video.
Thanks,
Darren
https://www.youtube.com/watch?v=r_r7IBeaPmY&index=13&list=PL0BB84111C070D080
