Genesis Nano Suit (Clear glass preset)
Midnight_storiesMidnight_stories Posts: 4,112
https://www.dropbox.com/s/naxtgf4egbjwtmf/Clear-Glass.zip?dl=0
Ok I've had a few requests for this a Clear glass preset for the helmet.
Just unzip to your Daz Studio content folder.
And a new folder under Materials called Glass will have the preset in it.
Sorry for not answering e-mails, super busy at the moment.
  • jerriecanjerriecan Posts: 470
    Thanks! The Nano-Suit was one of my first purchases and I love it.
  • XenomorphineXenomorphine Posts: 2,421
    Copied/pasted the files into the same branching folders, but no 'Clear Glass' settings or sub-folders seem to be showing in Daz Studio.
  • Midnight_storiesMidnight_stories Posts: 4,112
    I just download it straight from this page opened it up in winrar and it seem to be all there. See screenshot menu bar far path of the Zip. That's the best I can done !
    816 x 311 - 227K
    Do me a favor does the final directory say Nano-Suit or Namo-Suit that could be where the problem is I don't have access to my own product to check what it really is !
  • GoneGone Posts: 833
    Mine says Nano-Suit - but the original caustic glass shader will render clear just fine.
    The problem with the original shader is that it loads with the color and opacity channels as full white. In order to be clear, these channels have to have color values that are darker. The closer the values are to black the clearer the visor will be.
    Using dark colors (other than gray scale) in the color channel will give the visor a tint. eg: 0,0,128 will give the visor a blue tint.
    Argh... I know where I went wrong!
    See, I usually look either at the Smart Content panel or, failing to find anything there, I go through the A-Z of 'Products'. To new pre-set is there, but I forgot to go through the other manual search technique: DAZ Studio Formats -> My DAZ Library -> People... Etcetera. Then just following the directory path I'd copied it into.
    Sorry for the confusion! Works great now, thank you. :)
    Sorry have no idea on doing Smart Content Daz QA does it for us so we never need to touch it. But it give me a better idea why you couldn't see it, thanks for the feedback !
    Thanks for the heads up this was done so long ago I wish I knew this when I originally made !
