Problems making H.Material work in Cursed HD 8.1
Eggs ActlyEggs Actly Posts: 168
This character comes with an option to turn nose off in the Undead version, but I can't make this work when I apply the H.material for the No Nose. Anything needs to be tweaked or...???
https://www.daz3d.com/cursed-hd-for-genesis-81-male
Looks like this:
Post edited by Eggs Actly on
  • I don't owe the product, but according to the "what's included" there seems to be a material to turn off the nose. So, just in case, have you tried to apply that?
    Thanks for responding to my post :) Yes I've tried this as the first thing and it didn't work. Tried to delete and reinstall character but still no "no nose" for me :)
    Try to see if there's a morph dial to remove the nose. Perhaps the preset to turn off the nose isn't working, but the dial should be there (assuming the nose off effect is created through a morph).
    Can't find any morphs connected to this?
  • There are apparently two characters to load. The human and the undead version, right? So when you load the undead version, does it load without the nose?
  • The file list shows an HD nose remove morph
    No it loads with the red nose as the screenshot I posted. But I can sse that there is a morph for remove nose installed - I can see it when I search outside of daz.
    I can see that,  but nothing happens when I apply the "Cursed HD Dead - Nose Off"-H.material? can see any No nose dials at the Parameters- tab?
  • So it may be that your DAZ isn't loading the morphs at all, because your screenshot also looks more like the default Genesis 8.1 shape. Did you install manually?
    I installed through DIM - but I will try manual as well - thanks :)
    Solved - after manual install everything is working as it should - thanks for helping out :)
