How do you make buttons rigid?
WilmapWilmap Posts: 2,917
I need help with keeping buttons rigid.
I have no idea how to use Rigidity maps.
Can someone give me some tips please?
  • Richard HaseltineRichard Haseltine Posts: 109,440
    Is the problem in posing or in morphing?
  • WilmapWilmap Posts: 2,917
    It's when I pose the figure.
    In that case you need to make sure that the weights are the same for the whole of each button, so that they move as a unit - you should be able to use the Selection Analysis tab of the Tool Settings pane to get the weight of the mesh where the button is attached, and then fill the whole button with that value.
    I'll give it a go and see what happens. Thanks Richard.
