mcjQuad Plate - Morphing Mechanical Prop - 4 holes squarey plate
mCasualmCasual Posts: 4,607
edited October 2014 in Freebies
the holes will be movable
their radius adjustable
the many corners will be sharpen/unsharpen'able
the width/height/dept will be totally adjustable man, or woman if you are one
30 material zones,
"box" UV layout done using my free script mcjBoxUV
in fact it will be so morphable you will even be able to make a round 4-holes button ( 3000 polygons per button though )
https://sites.google.com/site/mcasualsdazscripts4/mcjquadplate
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited October 2014
    almost ready
    the morphs:
    Radius int 1
    Radius int 2
    Radius int 3
    Radius int 4
    Sharp Ext Top 1
    Sharp Ext Top 2
    Sharp Ext Top 3
    Sharp Ext Top 4
    Sharp Ext Bottom 1
    Sharp Ext Bottom 2
    Sharp Ext Bottom 3
    Sharp Ext Bottom 4
    Sharp Int Top 1
    Sharp Int Top 2
    Sharp Int Top 3
    Sharp Int Top 4
    Sharp Int Bottom 1
    Sharp Int Bottom 2
    Sharp Int Bottom 3
    Sharp Int Bottom 4
    Left
    Right
    Back
    Forth
    Up
    Down
    Radius ext 1
    Radius ext 2
    Radius ext 3
    Radius ext 4
    X Hole 1
    X Hole 2
    X Hole 3
    X Hole 4
    Z Hole 1
    Z Hole 2
    Z Hole 3
    Z Hole 4
    1448 x 724 - 141K
    1448 x 724 - 139K
    400 x 300 - 1M
    1248 x 640 - 260K
    edited October 2014
    492 x 492 - 37K
    960 x 540 - 50K
    - Update - Update - Update - Update - Update - Update - Update - Update -
    new version with object normals flipped
    this solves the all-black-render issues using advanced shaders like the cartoon shaders
    it also probably solves inverted bump/normal/displacement issues
    1600 x 900 - 65K
