Help, this is so weird
I need help as I have not modified any of the important files, but when I close her eyes an aberration appears, why does it happen?
Post edited by nicollegends on
Please don't post textured, nude images - and also, please don't reduce the size of screen shots as it makes them harder to read - using Snip And Sketch you could drage out a rectangle over the eyes, or you could zoom in more.
I couldn't sort out what was happening from thje image, but distorition is most likely down to a character with a correctove morph that is meant to kick in only when the eyes are shut and the character shape is applied; if it applies whenever the eyes are closed then the correction will be aplied when it isn';t needed and will distort the join. Had you installed any new characters just before thiss tarted to happen?
If you hadn't modified "any of the important files," what had you modified?
what happens is totally unreal
- Select the G8F (load the default Genesis without any morph applied, easier later to check what causes the issue)
- Parameters Tab > Options > Show Hidden Properties
- Parameters Tab > Currently used
- Now you can see all the dialed morphs. Close the eyes and if one of those hidden corrective morphs dials up by itself, you'll know it's the culprit.
- Click on the gear icon of this hidden corrective morph > Parameters Settings > Path. You'll know this way where is the file, how it's called and so on. Enough info to google for it and find out which DAZ bundle installs it.
- Exit DAZ. Uninstall this DAZ bundle. Restart DAZ.
All should be back to normal now.
