G81F Clothing Compatibility
captainklutz_a2ec859073
This is a request to vendors to please make G81F items backwardly compatible to at least G8F?
Yes, it is possible to autofit, but it is a time consuming process.
Thank you.
Post edited by captainklutz_a2ec859073 on
There is no need for vendors to set the compatibility of clothing to G8.1F.
If they have, you can change it by yourself;
- Do not select the figure when you load the clothing into the scene
- Select the piece of clothing
- Edit->Figure->Scene Identification
- Change the "Preferred Base" from Genesis 8.1 Female to Genesis 8 Female (the three dots on the right will open a list), click accept/ok.
- Select the clothing and fit to the figure
Thanks for the info. I wasn't aware of that one.
Whether that works out as any time saving will have to be experimented with, I suppose.
Thank you as well! I did not realize this either. :)
