Can I add multistate to a single button
Im looking to reduce the interface by adding multiple press state to a single button.
Rather than have individual buttons for Auto,  On,  Off. I would like to have a sinle button "State" when pressed 3 times would cycle throught Auto, On and Off. On the 4th press it would be back to Auto. I guess i could do it with a dropdown selection list also.
Any thoughts?
  • edited September 2021
    You could simply do it in a slot connected to the button's clicked signal.
    Just increment a variable each click, the fourth click resetting the value.
    Try this out, see if it does what you want:
    (function () {
        // a dialog
        var wDlg = new DzDialog();
        wDlg.caption = "tri-state button";
        wDlg.width = 200;
        wDlg.height = 200;
        //a button
        var wTriButton = new DzPushButton(wDlg);
        // set the initial state of the button
        var nState = 0// <--- THIS hold the button state, read it from wherever
        wTriButton.text = "Off";
        // make it pretty
        var wLayout = new DzGridLayout(wDlg);
        wLayout.addWidget(wTriButton1111);
        // connect a toggle counter
        connect(wTriButton"clicked()"doToggle);
        // records the state of the button for each click
        function doToggle() {
            nState += 1;
            if (nState > 2) {
                nState = 0;
            //update the button text
            updateButton();
        // updates the button text based on the toggle state
        function updateButton() {
            var txt = "";
            switch (nState) {
                case 0:
                    txt = "Off";
                    break;
                case 1:
                    txt = "On";
                    break;
                case 2:
                    txt = "Auto";
                    break;
            // set the button's text
            wTriButton.text = txt;
        wDlg.exec();
    edited text("Off") to "Off" so it "just works"
    Post edited by ghost_of_delete_key on
  • Qt's UI guidelines say that to select exactly one from a set of mutually exclusive options you users would expect to see radio buttons inside a group because all the choices are apparent, or a combo box if space is a premium. I think a command button might be slightly confusing because a command button is supposed to initiate an action, and it won't be obvious to the user what the button does, what the states are, etc..
    In your case, I think a combobox is most appropriate.
  • TugpsxTugpsx Posts: 832
    @ghost_of_delete_key Thanks this is what i was looking for but as TheMysteryIsThePoint said it may be best to present the users with the combobox rather than having to explain that the button has 3 states. It was a good Idea at one point. I will find future use for the assisted code again Thanks.
  • Darwin called this...
    Evolution.
    cool
