mcjStack - Full Stack ( Amplifier + 2 Speaker Cabinets for electric guitars
mCasualmCasual Posts: 4,607
edited October 2014 in Freebies
https://sites.google.com/site/mcasualsdazscripts2/mcjstack
it's a prop, with a total of about 17000 faces
there's no "real" knobs, it's a texture
all easily re-texturizable
Post edited by mCasual on
  • Tramp GraphicsTramp Graphics Posts: 2,421
    edited September 2012
    Definitely nice. This will definitely come in handy for renders of my character Ashley Chrome and her band.
    Post edited by Tramp Graphics on
  • mCasualmCasual Posts: 4,607
    ~ Update ~ Update ~ Update ~ Update ~ Update ~ Update ~ Update ~ Update ~
    one of the speakers cabinet had a texturing issue for Daz Studio renders
    a new version of mcjStack has been uploaded
    1280 x 960 - 262K
  • ThatGuyThatGuy Posts: 797
    thank you. very nice and generous indeed.
  • waningmoonwaningmoon Posts: 30
    thanks for these. \m/
    regards,
    waningmoon
  • ScavengerScavenger Posts: 2,674
    Wow..This is a great model, just what I was looking for!
    using a script like mcjRibbons ( https://sites.google.com/site/mcasualsdazscripts/mcjribbons )
    you could make the guitar cable ( it's tricky but it can be done )
    1920 x 1200 - 394K
    Thanks..I may try that to put more tools in my arsenal.
    Something I really liked about this set compared to a number of other "freebies" I've found, is that each of 3 parts are actually their own parts. The 2 speakers was higher than I wanted, so I removed the bottom speaker and lowered the set. That kind of customization is golden.!
    edited October 2014
    i'll see if i kept the grille texture image that reads "Marshall" and post it right here
    well .... they are not really really realistic but they were the starting point for the Merswild grilles
    617 x 185 - 44K
    1024 x 1024 - 442K
    1600 x 900 - 251K
    That ribbon script looks REAL complicated at my current level of use..I'm re-outfitting a bar scene and was toying with the idea of placing neon tubes along the molding, curving around. One of those "In photoshop, I can do this easily...how would I do this in Daz" things which turned out to be "you won't do it in daz"...thought briefly your ribbon script could get it done...likely could when I know how to stuff more.
    edited October 2014
    if you look over here
    https://sites.google.com/site/mcasualsdazscripts2/mcjspeaker
    the woofer/speakers can be extracted from the enclosures
    so you could make the Marshall grilles transparent ( 0% opacity )
    and add 4 woofers in them
    though you'd need a backplate
    ... which could be created using a simple plane and this opacity map:
    1600 x 900 - 524K
    1024 x 1024 - 40K
    edited October 2014
    about (fake) neons
    say you create a primitive-plane in Daz Studio
    and apply the 1st image below to the diffuse color channel of the surface/material
    then apply the 2nd image below to the opacity channel l of the surface/material
    then everywhere the 2nd image is white you get opacity, the rest is transparent
    then you set the "ambient" color to white and the ambient strength to 100% ( or 50% )
    and you get fake neons
    those fake neons dont really emit light, so you could add "spot lights" and position them very carefully and get a bit more realistic
    there's also AreaLights which are part of Daz Studio 4.6 which could make it even more credible
    and if someday you have a few hours .... there's
    https://sites.google.com/site/mcasualsdazscripts/mcj-glow-kit-for-nerds
    and
    https://sites.google.com/site/mcasualsdazscripts/mcjsevenarcs-prop-and-script
    1600 x 900 - 341K
    400 x 400 - 3K
    400 x 400 - 4K
    Very cool...what I'm more wanting to do is something ala the pic below..I mean, I could make tube primitives for the straight lines but it's the curving join ppieces I don't know about.
    600 x 324 - 76K
    edited October 2014
    Daz Studio can make torus shapes
    by making parts of the donut transparent you get your bent tubes
    there's a drop-down menu which lets you select the camera view
    one of those views ( "UV View" ) lets you see the texturing layout of the currently selected object
    ( for higher precision texture maps get https://sites.google.com/site/mcasualsdazscripts2/mcjtemplate )
    you need this to create the opacity/texture map
    well actually you can see here the texture map for the torus couldnt be simpler
    so lets make 3/4 of that map black and the rest white
    apply this to the Opacity channel of the surface
    then make the ambient channel of the surface white 100% strength
    or you can download eigthdonut.obj and quarterdonut.obj
    here : https://sites.google.com/site/mcasualsdazscripts4/bric-a-brac
    then in daz studio do File / Import / Wavefront Object (.obj)
    specify "Daz Studio 1unit = 1 cm" as the import scale
    960 x 540 - 261K
    525 x 526 - 3K
    525 x 526 - 53K
    1750 x 538 - 108K
