Aeon Soul: Iray textures for 'Out Of Print' products available?
I wasn't sure whether to if I should ask this question here, or in Technical Support, but, as it refers to a product, I think here is best.
As the title says, one of the things I would like to see is Iray textures for some of the older Aeon Soul products (when he/they went by other names in the past).
In particular, I would like to see Iray textures for the old Earthbreaker armor set for Victoria 4 (see attached image).
I have been able to use the base armor in Daz (and even fit it to Genesis 3 and Genesis 8 with a 3rd party app), but of course the textures don't transfer.
Even using various techniques to convert them to Iray (that I know of, anyway), the textures on the armor still come off as 'painted on', instead of the extreme level of detail they have in Poser.
Does anyone know if Aeon Soul has made Iray textures for his older, 'out of print' products, or where to find them?
If not, well, that's the suggestion I have to make smiley
  • I hear you!
    I wish that AS would get an intern, and put them to the task of converting their old items to Current Generation with Iray....
  • chris-2599934chris-2599934 Posts: 1,904
    Sounds to me like the textures involve a lot of displacement, which doesn't always work well in iray. Try increasing the SubD value and/or converting the displacement map to a normal map.
  • richardandtracyrichardandtracy Posts: 7,240
    edited September 2021
    It may also be an artefact of the version of DS being used. I'm sure 4.12 did more displacement with the same setting than 4.14 & 4.15. I haven't done a test to verify, but it is a feeling. I have tried to use displacement in the latest version & been a bit disappointed by the results.
    ETA - try it using the Filament Renderer. I noticed I was getting very obvious displacement with Filament yesterday evening. Might even say a 'Disconcerting' amount.
    Regards,
    Richard
    Post edited by richardandtracy on
  • Well, I'm new enough to not know what "Increasing the SubD Value"  or using the "FIlament Renderer" is, but thanks for the answers ^_^
    I'll do some googling later to get tutorials on those and see if they work, but you are both right: the Poser textures rely heavily on Displacement, as they are not part of tha actual geometry itself.
  • To get the filament renderer to work: In the viewport you can choose the type of display you see. The options are texture mapped, smooth shaded, wire frames, hidden line, iRay etc. The bottom one of the list is the iRay preview. The lightbulb icon above the iRay preview selects the Filament Renderer. After choosing the filament renderer you will find everything looks washed out. To prevent this, you need to create a 'Filament Render Settings'  node (I am away from my machine so I don't remember the exact name, sorry, but it's in the bottom 2 or 3 menu options of the 'Create' menu). Once created, select the Filament Settings node in the scene tree, and under the parameters tab, chose the parameter that says 'Film ISO' or some similar name. This will be set to 1.00, change it to 0.25 to stop the scene being so washed out. Now you are using the filament renderer as your rendering preview. There are ways to use it as the main rendering engine, but I fear someone else will need to tell you how as I have never tried it.
    One thing I have never been able to prevent in Filament is back face culling, and as most hair models seem to have normals pointing to the head, back face culling makes hair models, in particular, look a bit odd.
    Regards,
    Richard
  • I am now wondering if the Thickener plugin would solve the Filament transparency issue.
  • It could well do, at the expense of a vast number of extra facets. There are one or two hair models with 500k+ facets and that may well take a huge time to do. I have a thickener I wrote into my own modeller 2 years ago. When I thicken clothing for 3D printing, no problem. Thickening hair... A few are OK (Jim Burton's V3 Las Vegas Hair is one, as well as many of the old Koz Hairs). My modeller works with up to 1 million facets or so, but there are hair models that blow it out of the water when thickening the hair.
    OK, here's how to go about trying to get those textures to work in Iray...
    • Select the item in the Scene tab.
    • Open the Surfaces tab and click on the item there to select all its surfaces
    • In the Content Library, go to Daz Studio Formats/My Daz3D Library/Shader Presets/Iray/Daz Uber and double-click on !Iray Uber Base. This will convert the all surfaces to use the Iray Uber shader.
    • Now, back on the surface tab, work through the surfaces one at a time (you might be able to do several at once if the all use the same settings, but let's assume they don't). It's best to do this bit with the viewport set to Iray preview mode, so you can see the effect of the changes you make
    • Looking at that outfit, you might want to experiment with giving it some Metallicity, though for coloured metals like that you can often get a better effect by leaving Metallicity alone, using the Base Color image in Metallic Flakes Color, and using metallic flakes instead.
    • You may find maps in the Glossy Layered Weight are useful in controlling metallicity too. You may also find that such maps for Poser are the wrong way round for Daz - in Daz white means most glossy, black means least. I think Poser does it the other way around.
    • Scrolling down, see if the surface has a Normal Map defined, because if it doesn't that gives you a Plan B (see later).
    • Keep going till you reach Displacement Strength. This is where your displacement map is, followed by the min/max amount of displacement. But in Iray it only applies that displacement where there's a vertex that can be moved. Meshes are rarely dense enough for that to work well, so you have to subdivide: Increase the SubD Displacement Level till you get the level of displacement detail you want, or your machine collapses in a heap. I rarely try to go beyond 3 or 4, but you might be braver. Probably best to save your work before attempting this step.
    • If you can't get the displacement approach to work for you, it's time for Plan B: you may be able to get away with a Normal map instead (assuming there isn't one already). Find the image used as a displacement map, and turn it into a normal map here: https://cpetry.github.io/NormalMap-Online/ . You can then remove the displacement map from your surface and apply your new image to the Normal Map channel instead.
    • Different approaches may work best on different surfaces, which is one reason to tackle them one-by-one.
    • Once you've got it looking as good as you can, save it as a Materials Preset.
    Good luck!
