NVIDIA Resizable Bar?
MelissaGT
Does anybody know if NVIDIA's Resizable Bar is something that works/will work/has been approved to work with Daz Studio? I've enabled it and I might be crazy, but it feels like I'm getting performance loss on my older MMO's...but if it legit helps Daz/Iray I'll keep it enabled.
Post edited by MelissaGT on
This appears to be related to manging data transfer across the PCI lanes - if so it isn't likely to havea tremendous impact, certainly for rendering, as the scene data is transferred once at the beginning of the render and then worked on (space permitting) in the GPU memory. If it takes up extra GPU memory for its own working it might well have a negative impact. It might, subject to that caveat, have a noticeable impact on how quickly the preview updated if using Iray drawstyle to navigate the scene during set up.
I was under the impression that resizable BAR support was only significant for out-of-core rendering when textures are shuffled across the PCI bus during rendering. Not really significant if the scene fits in GPU memory. I could be, and probably am, wrong.
I was thinking more along the lines of scene set-up and navigation, and flipping between texture shaded and Iray preview.
No, resizable bar wouldn't make a noticeable difference as its intended to alleviate the stuttering experienced in some games and give a slight boost to FPS.
You can read the full article, which I recommend, on Trusted Reviews: https://www.trustedreviews.com/news/what-is-resizable-bar-4150689 that gives a list of current games that support it.
I ended up disabling it as I was indeed suffering a performance loss on my older games. That and the GPU was getting hotter. Playing Star Wars: The Old Republic last night and GPU was hitting 75C. Disable Resizable Bar and GPU topped at 57C back in-game. Big difference. Not sure why people are even bothering with it.
Its more for those who are having issues with certain games; especially those who are trying to do "redline" gaming where they're attempting to max out their FPS as high as possible with overclocks, etc. The good thing is you don't need it, but will at least have the option available if you ever want to play a game that supports it.
