Daz Central - entry point not found
This discussion was created from comments split from: DAZStudio.exe- Entry Point Not Found ...??.
when i run the dazcentral.exe it raises an error. that error is entry point not found - the procedure entry point _Aligned_Default_resource could not be located in daynamic library C:\Program Files\DAZ3D\DazCentral\QT5XML.dll
Split to its own thread since the other thread was about an issue, long ago, with Daz Studio rather than Daz Central.
What are your system specifications and operating system? What security software are you using? Were there any errors when installing Daz Central?
