Thick fabric?
I've been playing with D-form to change clothing and to drape sheets over shapes. I will get to creating my own clothing from scratch at some point, but I need to learn to walk before I run.
Clothing always seems paper-thin to me. If I want to createa a sweater or a space suit, the clothing needs to be noticably thick.
D-forming a plane can create a sheet or a silk scarf, both of which conform nicely to shapes.
I tried Y-scaling up a plane- no dice. It is two dimensional.
I tried starting with a cube, Y-scaling it down to .5cm think, and d-forming that. The results, after an hour of processing, looked like H R Giger tried to draw a hedgehog. Not what I was seeking.
So, how can one make clothing thick, using only DazD?
Thank you.
Use the Thickener plugin.
A Push Modifier.
You will then be doing better than 90% of the rest of DS users since that is the biggest creation obstacle. best of luck!
