Indent on bed or couch tool
Shockwave
Is there a tool or script that easily indents texture/material such as when a character sits on a couch or bed?
I've seen the YouTube videos on how to use a d-focre modifier but it seems like a daunting task and when I tried it it just didn't come out right.
Just trying to see if there is an easier way such a tool that someone created to make indent impressions on any surface.
thanks
Does it need to be interactive? If not, you can use a weight-mapped D-Former to do that, if there are enough polygons in the mesh to retain some detail. It basically acts as a portable morph, which you can move around and adjust the intensity. It is non-destructive and just needs a little skill at painting weight maps.
Try Mesh Grabber:
Windows - https://www.daz3d.com/mesh-grabber-bundle-win
Mac - https://www.daz3d.com/mesh-grabber-bundle-mac
Interactive in that it would indent just by placing the figure on the cushion. Something with dForce would be interactive, but, as you say, might be tricky to set up. That said, there are some dForce cushions and other soft-surface props around, but I've never actually used them. Mesh Grabber would do the same as the D-Former, but it is more or less permanent without its Morph Editor add-on.
