Fatal Error on first attempt to open Daz Studio
13
  • Update  -- A friend suggested a fix - - I posted it once, but it was taken down by moderators, so won't post the link again, but it involved an OpenGL fix and pasting that dll into Daz Studio...  Try it at your own risk.
    It got the program to open, but the veiwport is laggy as Hell - - really to the point of being unusable (them I'm tempted to try, with extreme levels of patience).  Could anything else, besides the missing OpenGL issue, be causing viewport lag?  I only ever use the fastest render settings and could make due with even screenshots - - but simply rotating in veiwport, even with no figures loaded, takes several seconds.
  • Omniflux said:
    You could also try going to your BIOS / UEFI and disabling the Intel graphics or setting the primary to be the AMD (may be called Discrete).
    Do you think the BIOS/UEFI could be causing the veiwport lag?  The OpenGL issue appears to be solved (though maybe some aspect of that is responsible for the vewiport lag?)
  • OmnifluxOmniflux Posts: 428
    The BIOS/UEFI change should only affect the OpenGL dll Windows chooses. I have no idea if the OpenGL dll you chose would cause viewport lag.
  • What things could cause veiwport lag?  Going through a list of potential problems might help.
    What are your settings in Edit>Preferences>Interface? What Drawstyle is the Viewport using?
    Haven't messed with it, so the default. Right now I'm using an older version of Daz that I hoped might be less demanding on graphics, since I have an AMD card, instead of the preferred Nvidia and this old version ran off my old computer's CPU with no problem... but that was Windows 7.  If you think the more up to date program might be smoother I could give that a try.
  • AMD vs nVidia shouldn't matter for most Viewport Drawstyles (with the obvious exception of Iray). Depending on the age of the version you are using the Display Optimisation in the Interface tab of Preferences may be set cautiously - try setting it to Best and see if that helps.
    The version I'm currently trying to use doesn't have a "Best" under Display Optimization, just an on and off... the default was off, so I turned it on... but still, in an empty scene, just tryng to rotate the grid floor, it takes 10 - 15 seconds btween the action and the result ( I counted).
    Figures do load as fast as before (no complaint, there), but the rotation is difficult, with the 10-15 second lag.  I haven't tried to see if there's a lag in posing yet.
  • You don't have something like the attachment? Which version of DS is this?
    434 x 517 - 48K
    Daz Studio 4.0,3.47 -  I first downloaded it in... maybe 2012, I think. It just has "Off" and "On" for Displaty Optimization. I don't know if the newer version would work better or worse... I thought the old version might be simpler and could work better, but maybe not.
  • The older version may not be coded tot ake advantage of modern hardware. If that is the correct version number it's from before the official release (which was 4.5.x.y) so you may well have all sorts of compatibility issues.
    I'll give the new version a try and plug in the openGL fix there. I've been wanting to try some files that won't work in the old version, anyway... though if I could get the viewport working, the old version would be fine - - I'm used to it and have a lot of files and characters/scenes saved.  It worked great on Windows 7, but a lot of things worked great on Windows 7 and are buggy on 10.
  • Thanks, everyone  - I didn't uninstall  the old version but did "re-install" through DIM (with my irregular internet connection it seems to work better than Daz Central) Daz 4.15 or whatever - - the basic free version available - - the empty viewport rotates smoothly again, but trying to load characters produces an error. Where do I find the log?
    414 x 99 - 4K
  • Are you sure it wasn't a preset that requires a target item to be loaded and selected?
  • edited August 2021
    No, I'm not sure.  I'm not entirely sure what you mean.
    Edit - - I found the textures... but not sure why Daz Studio isn't finding the presets?  I have some whole multi-character scenes saved... I'd rather not have to re-do everything from scratch, if I can at all help it.
    Post edited by mlpetersmail_b79b0d6b5f on
  • Most presets, except character presets, will give that message if they are double-clicked when there is nothing selected in the scene.
    It was a character preset I was trying to load.
  • Help>Troubleshooting>View Log File just after getting the error, and scroll to the very end.
  • Here's part of the log - - The "Exception Memory Access Violation" bit might be the relevant part and the rest follows from there?  That's at a guess...  Any clue on fixing?
    I picked a character at random - - one that didn't have a lot of props and scenery.  I have many that are more complicated and would hate to have to rebuild from scratch...
    2021-08-28 23:13:53.480 Error setting pointers while reading file C:/Users/Mike/Documents/DAZ 3D/Studio/My Library/People/Genesis/Characters/Corrina.daz : C Exception: Memory Access Violation - Attempted to read memory at address 0x00000000
    2021-08-28 23:13:53.480 File read time: 0 min 6.4 sec.
    2021-08-28 23:13:53.550 Building Scene...
    2021-08-28 23:13:54.101 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.102 WARNING: Object::disconnect:  (sender name:   'CTRLlHandStraighten')
    2021-08-28 23:13:54.102 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.102 WARNING: Object::disconnect:  (sender name:   'CTRLlHandSpread')
    2021-08-28 23:13:54.102 WARNING: Object::disconnect:  (sender name:   'CTRLlHandGrasp')
    2021-08-28 23:13:54.102 WARNING: Object::disconnect:  (sender name:   'CTRLlHandFist')
    2021-08-28 23:13:54.103 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.103 WARNING: Object::disconnect:  (sender name:   'CTRLlFingersInOut')
    2021-08-28 23:13:54.131 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.131 WARNING: Object::disconnect:  (sender name:   'CTRLrHandStraighten')
    2021-08-28 23:13:54.131 WARNING: Object::disconnect:  (sender name:   'CTRLrHandSpread')
    2021-08-28 23:13:54.132 WARNING: Object::disconnect:  (sender name:   'CTRLrHandGrasp')
    2021-08-28 23:13:54.132 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.132 WARNING: Object::disconnect:  (sender name:   'CTRLrHandFist')
    2021-08-28 23:13:54.132 WARNING: Object::disconnect:  (sender name:   'CTRLrFingersInOut')
    2021-08-28 23:13:54.147 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.147 WARNING: Object::disconnect:  (sender name:   'CTRLVSMW')
    2021-08-28 23:13:54.147 WARNING: Object::disconnect:  (sender name:   'CTRLVSMUW')
    2021-08-28 23:13:54.147 WARNING: Object::disconnect:  (sender name:   'CTRLVSMTH')
    2021-08-28 23:13:54.147 WARNING: Object::disconnect:  (sender name:   'CTRLVSMT')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMSH')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMS')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMOW')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMM')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSML')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMK')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMIY')
    2021-08-28 23:13:54.148 WARNING: Object::disconnect:  (sender name:   'CTRLVSMIH')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLVSMF')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLVSMER')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLVSMEH')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLVSMAA')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLSmileSimpleR')
    2021-08-28 23:13:54.149 WARNING: Object::disconnect:  (sender name:   'CTRLSmileSimpleL')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLNostrilsFlare')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLNoseWrinkle')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLNeckHeadTwist')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLNeckHeadSide-Side')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLNeckHeadBend')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLMouthSmileOpen')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLMouthSmile')
    2021-08-28 23:13:54.150 WARNING: Object::disconnect:  (sender name:   'CTRLMouthSide-SideR')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthSide-SideL')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthOpenWide')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthOpen')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthNarrowR')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthNarrowL')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthFrown')
    2021-08-28 23:13:54.151 WARNING: Object::disconnect:  (sender name:   'CTRLMouthCornerUpDown')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipTopUpR')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipTopUpL')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipTopDownR')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipTopDownL')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipsPuckerWide')
    2021-08-28 23:13:54.152 WARNING: Object::disconnect:  (sender name:   'CTRLLipsPucker')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipsPartCenter')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipsPart')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomUpR')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomUpL')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomOutR')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomOutL')
    2021-08-28 23:13:54.153 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomInR')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomInL')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomDownR')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLLipBottomDownL')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLJawSideR')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLJawSideL')
    2021-08-28 23:13:54.154 WARNING: Object::disconnect:  (sender name:   'CTRLJawOut')
    2021-08-28 23:13:54.155 WARNING: Object::disconnect:  (sender name:   'CTRLJawInOut')
    2021-08-28 23:13:54.155 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.155 WARNING: Object::disconnect:  (sender name:   'CTRLJawIn')
    2021-08-28 23:13:54.155 WARNING: Object::disconnect:  (sender name:   'CTRLGlare')
    2021-08-28 23:13:54.155 WARNING: Object::disconnect:  (sender name:   'CTRLFear')
    2021-08-28 23:13:54.155 WARNING: Object::disconnect:  (sender name:   'CTRLEyesUpDown')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyesSquintR')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyesSquintL')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyesClosedR')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyesClosedL')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsTopUpR')
    2021-08-28 23:13:54.156 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsTopUpL')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsTopDownR')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsTopDownL')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsBottomUpR')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsBottomUpL')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsBottomDownR')
    2021-08-28 23:13:54.157 WARNING: Object::disconnect:  (sender name:   'CTRLEyeLidsBottomDownL')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLConcentrate')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksFlexR')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksFlexL')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksEyeFlexR')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksEyeFlexL')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksCreaseR')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksCreaseL')
    2021-08-28 23:13:54.158 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksBalloonPucker')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLCheeksBalloon')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowUpR')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowUpL')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowSqueeze')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowOuterUpR')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowOuterUpL')
    2021-08-28 23:13:54.159 WARNING: Object::disconnect:  (sender name:   'CTRLBrowOuterDownR')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowOuterDownL')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowInnerUpR')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowInnerUpL')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowInnerDownR')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowInnerDownL')
    2021-08-28 23:13:54.160 WARNING: Object::disconnect:  (sender name:   'CTRLBrowDownR')
    2021-08-28 23:13:54.161 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.161 WARNING: Object::disconnect:  (sender name:   'CTRLBrowDownL')
    2021-08-28 23:13:54.161 WARNING: Object::disconnect:  (sender name:   'CTRLAngry')
    2021-08-28 23:13:54.168 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.168 WARNING: Object::disconnect:  (sender name:   'CTRLrFootTwist')
    2021-08-28 23:13:54.174 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.174 WARNING: Object::disconnect:  (sender name:   'CTRLlFootTwist')
    2021-08-28 23:13:54.180 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.180 WARNING: Object::disconnect:  (sender name:   'CTRLArmsUpDwnRight')
    2021-08-28 23:13:54.180 WARNING: Object::disconnect:  (sender name:   'CTRLArmsUpDwnLeft')
    2021-08-28 23:13:54.220 WARNING: Object::disconnect: No such signal QObject::currentValueChanged()
    2021-08-28 23:13:54.220 WARNING: Object::disconnect:  (sender name:   'Value')
  • A .daz file is really old, and they can be problematic. If that's content from a store check there isn't a newer version in your account's downloads.
    No, it's not store content.
  • You might try getting the SDK, which includes Daz Studio 4.5, and see if that will open the scene and then let you resave it (or save presets to rebuild it).
    "SDK"? What's that?   I'm not up on all the abbreviations.
  • LeanaLeana Posts: 12,806
    edited August 2021
    https://www.daz3d.com/daz-studio-4-5-sdk
    SDK means "software development kit", it includes tools for people who develop plugins.
    The product also includes a version of DS 4.5, which might be able to open your old .daz files so you can re-save them as .duf
    Post edited by Leana on
    Thanks  -- are there instructions on how to install it (I'm not using Daz Central - - I use DIM)?  Instructions on how to save as .duf?  Did .duf replace .daz as the default multi-part file extention?
  • As I recall you would make sure your content directories were correctly set, open the .daz file, and use File>Save As to save a .duf version.
    Any tips on that?  The content directories fom that early version I had been using was different, I'm guessing, and might be part of the problem?
  • The character files still won't open. Same error -  "C Exception: Memory Access Violation"
  • Do you know which version of DS the files were saved from?
     Daz Studio 4.0,3.47
