Daz to Maya Bridge not loading on Maya 2019
Hi there! After new update from Daz plugin, I can't load the plugin on Maya 2019. On Windows>Setting>Preferences>Plug-in-Manager more than one DazBridge plugin are showed and no one works. Please, any reference to resolve this? Thank you so much in advance! Steph.
p.d;
Error: file: F:/AUTODESK/MAYA2019/scripts/others/pluginWin.mel line 316: Plug-in, "C:/Users/WINDOWS/Documents/maya/plug-ins/DazToMaya.pyc", was not found on MAYA_PLUG_IN_PATH. //
This is the error message
trying to load manually on Maya using the Browser option, this is the error message:
// Warning: file: F:/AUTODESK/MAYA2019/scripts/others/pluginWin.mel line 938: Could not load C:/Users/WINDOWS/Documents/maya/plug-ins/DazToMaya.pyc as a plug-in //
I think the updated bridge has moved where it places the plug-in. So you won't see it or manage it from the plug-in manager. It is now it's own shelf. So if you look at the shelf tabs (poly modeling, curves, animation, whatever... those tabs) Daz to Maya should now be its own tab at the end. If you select it you will have two buttons, one for DtM, and one for the rig somethingsomething...
Check out your shelf line and see if it's there.
Hi Banshee, thank you so much for your reply. The only I see is two DaztoMaya icons on scripts tab as you'll see on picture below, but no one of both works properly. =(
Hey Steph—
Sorry for the delay. Maybe you've sorted this out by now, but here is a screen shot of where the tab is for me, on the shelf tab row.
EDIT: And I just looke at you pic and realize you are talking about the Daz side, not the Maya side... So from Daz you use that Scripts tab to use the Daz to Maya bridge, and this should put the file in some temp folder. Then, in Maya, you select the plug-in and have it load the D2M file and it comes in. Theoretically.
At what point in the process are you experiencing your issues?
Hi Banshee! Yeah, sure. I've got the 2 icons there but none works. Also, on Daz the new bridge icons are hidden o missed, just keep the older options on "script" tab but unuseful. =(
