Artefact on teeth
Hello everybody! Recently I bought Agma Bundle and doing a close-up this happen on her teeth. I was looking on textures but no idea how to fix it. Any idea???
Thanks!!!
  • charlescharles Posts: 866
    Oh yeah that's like the shader setting, i've had that before. There is some teeth assets that add it then when you reapply other teeth it doesn't actually remove the effect.
    First do you ahve a geoshell on the character? If so turn it off and see if that fixes it.
    Next applying another characters skin, copy the surface teeth to buffer (CTRL+C), het undo to revert back to your models skin and select surface teeth and paste (CTRL+p)
    Or check your teeth surface shaders Base Mixing and make sure it's set to PBR Metallic/Roughness. Check Thin Wall off and opacity is all the way up and that SSS is off.
  • OK I tried with another character and no problem. So I guess Agma have this issue for some reason.  Take care!
  • SpaciousSpacious Posts: 481
    Don't just give up on it.  Charles just explained a pretty easy way to fix just the teeth texture and keep the same surfaces for the skin.  In fact all three of the suggestions he made could help with this, and also many of the other troubles that frequently pop up.  Don't miss out.  Learning how to mess stuff up and fix it again is half the fun of this software, and if you keep at it, it's where most of the creativity comes in.
