Posing the hood on the dForce Fall Vibes Outfit for Genesis 8 Hoodie
Hey guys! So I downloaded this outfit for the hoodie, and in the promos I see the hoodie laying flat against the characters back, but even with the 'hood helper' adjustment in the shaping tab, I can't get the hoodie to go all the way back. Any suggestions? It doesn't matter what pose I use e.e
The clue is in the name.
Use dForce.
While I neglected to mention it, I did run simulation settings, with very little difference made.
Reapply the product's material settings to the hoodie, since that's where dForce data is stored.
Then, make sure "Visible in Simulation" is set to "True" and "Freeze Simulation" is set to "False" for the hoodie.
Finally, go to the Simulation tab and hit "Defaults" to reset it.
If it's still not simulating, something's wrong with your setup. In that case, we'll need more information.
