Slime Beast Assistance
I recently bought the Slime Beast critter for use some Fantasy and Sci Fi renders. I was curious to know if there's a way to make the thing more clearer and sort of gelatinous looking sort of like the tradtional Gelatinous Cube. Is there some kind of a setting I can play with or a shader I can use?
Thanks for your help!
Okay, never mind! I found the Opacity slider under the Surfaces tab in the corner of Daz! Just going to leave this up in case somebody else has the same question at some point... :-)
You'll get way more realistic results with the REFRACTON WEIGHT and REFRACTION INDEX sliders. Those are volumetric effects. The CUTOUT OPACITY slider just makes stuff fade to invisible.
