EYE disappeared
The EYE disappeared from my DAZ Studio "Scene" window. I don't see a setting that adds or removes such things. Any ideas about what happened? See attachment.
  • SpaciousSpacious Posts: 481
    I'm not understanding what you mean.  Maybe you could explain more, or post another screenshot?  I don't see anything strange in the picture you posted.  Maybe someone else will.
  • GordigGordig Posts: 10,642
    The Scene pane usually has an eye-shaped icon to show/hide objects, as well as an icon that toggles whether that object is selectable in the Viewport. Those are missing in the screenshot. To the OP, I did some digging around, and couldn't find an option anywhere that seemed like it would affect those icons, so try Window -> Workspace -> Update and Merge Menus and see if that fixes it.
  • PiquantPiquant Posts: 349
    Yes, Gordig, that's what the problem is. The show/hide eye is missing. I did try what you suggested but that didn't work. Is DAZ doing something that would effect this?
  • Is this affecting all scenes?
    Ok.  Now I see what's missing.  Looks like the text for "Environment Visualizer ...." whatevr that is, I'm not sure, is really long and overrunning the space available in the properties pane.  There should be a horizontal scroll bar at the bottom of the pane so you can scroll left/right to read everything and I bet that will make the visibility eye icons show up.  Alternately you could change the name of that item so it's shorter and fits, or expand the properties tab so it's wide enough to display everything.  Sorry I didn't notice that in the forst place.  Hope this helps.
