all g8.1f model doesn't load correctly, help please
Meraki
So for a while now, all my g8.1f model looks broken, just doesn't load correctly, i need help please. i can't use any 8.1f model.
left genesis 8.1 right genesis 8
That looks like a non-zero default value for a morph. Check that you aren't missing an update (the Daz install methods can all show updates thata re available; for manual you are going to need to check the zips). If updates don't help then there is a way to fix the issue:
How do you install your content? If it's not through Daz Studio itself you can probably fix this by loading the Dev Build version of the figure, then Edit>Figure>Zero>Zero Figure Shape, then File>Save As>Support Assets>Save Modified Assets.
do i need to do that for every model that i have?
You have only one "Genesis 8.1 Female Dev Load" and it can be found in "...\People\Genesis 8 Female\Developer Kit\".
When you zero her (and memorize figure) and "save modified assets", it will fix the non-zero default value for whatever character that's causing the problem.
I have another issue then, i don't have the dev kit folder because i can't login with daz, postsql error everytime, it is allowed in my firewall, i don't have any anti virus software who could have blocked it and i have the port open
Edit: i fixed it, i'll try to fix my model problem later
The DevBuild is part of the base Genesis 8 Starter Essentials install, with versions for both 8 and 8.1.
Okay so i tried that, and it fixed the dev model which is great, but then i save it and reload the model to see if it fixed it and it just load the model back with the problem
That means you didn't save like Richard adviced, or that you have previously saved some character as "Asset" before.
Zeroing the figure, memorizing it and saving Modified Assets fixes the very problem you describe and it only needs to be done with the base G8F/Developer version as every other "character" you have is just a morph, not a real figure.
Sorry, I missed the memorising step.
how do i memorise it? because i followed exactly what was said
edit: found and fixed it, thx you very much for your help
Just for anyone finding this later: Edit>Figure>Memorise>Memorise Figure Shape
