Stonewalls
I bought stone walls and installed it while using the install manager, and now I can't find it. How do you use the stonewalls?
Aren't they 'just' textures, so you'll need to track down where they installed to and apply the to the Diffuse map of the required surface. If you used DIM you can get it to tell you where it put them.
Yes they are just textures, Actually a Merchant Resource, so will just contain the JPGs
They are installed into your Library under General. They are jpg files that you can add to objects.
I couldn't find where the install manager had put them. There was no file folder created called General, but to solve my problem, I did a normal download and open the zip file.
In DIM, from the Installed tab ...
