Default G3F load with weird looking face.
Hi,
Something stange happened to my default G3F, if basically load with weird looking face like this:
As you can see there is characteristic "spiky" nose, and now if i want to load some other preset to default G3F it looks even worse like this:
Everything looks fine in Parameters tab/Currently Used. Tried to reinstall G3 but didn't work.
Any idea how to fix it? Thanks!
  • It's probably a recently installed character with a non-zero default value. Does Edit>Figure>Zero>Zero Figure Shape fix it?
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Richard, would the show hidden properties checkbox affect what is seen in the currently used section?
    Yes, if something is currently used but hidden it won't show unless show hidden is on.
