Textures - Adjustment of size
The dirty old walls textures are really nice: high resolution, seemless continuation.
But is there a simple way to adjust the size according to the object?
Or do I have to modify it by picture editing?
http://www.daz3d.com/new-releases/texture-resource-dirty-old-walls
If you go to the surfaces tab with the wall selected and scroll all the way to the bottom of the options, you will see tiling and offset options
or you could click on the little arrow in the lower right corner of the image in the diffuse setting and select the layered edit option to increase the size and positioning of the image
Thank you very much for you hyper fast help, dear kaotkbliss! This was simple for you but for me a useful different way to use the tiles function ;)
