francine Dress similar like this
Hello i need find a daz Dress for genesis 3/8 or any daz genesis model like this with the
white lace. the most similar I searh but is not easy to find a simple normal dress like this.
Post edited by gocuzero on
Actually, I have seen similar; I don't remember where though.
JUST A SIMILAR DRESS
YES Just similar is enought.
I think you may well need to do a little bit of work to get a similar dress. Can I suggest a starter of the free subscription dress 'Free Lace Dress 3' from MostDigitalCreations here: https://www.most-digital-creations.com/g8f_lace_dress_3.php You will need to sign up for the weekly e-mail to get it, but it's once a week & no real problem. The lace on that dress is all in the texture/transparency map. What you would need to do is to edit the trans map to make most of it solid, and on a diffuse map based on the transmap (don't think it comes with a diffuse map) change the colours so the lace is white and the solid area is pink. That will get you close to where you want to be. I would hope it's close enough. If not, have a good search through here: https://www.most-digital-creations.com/freestuff.htm as some may inspire you. A couple of Arryn's dresses are a bit like it, but the similarity is not great (https://www.daz3d.com/dforce-kasey-candy-dress-for-genesis-8-females is probably the closest)
Sorry not to be of more help.
Regards,
Richard
Check in Arryn Onnel stores under vendors here in DAZ
thanks
this is simlar. you can add lace with textures.
https://www.daz3d.com/dforce-ayria-s-closet-g8f-and-g8-1f
