use personal obj avatar in Daz
hi
i want use my other avatar in daz,
i have obj , fbx file, made in z brush, and can i use this file in Daz as Avatar?
plz let me know the method. thank you!
hi
You can import an OBJ or FBX through File>Import (in the case of OBJ you will need to mak sure that you are using a suitable preset to get the correct scale and orientation) but you will then need to rig it, which is most easily done if it is grouped by bone already and you import it into the Figuire Setup pane (by right-click in the groups area) and then adjust the hierarchy to get the basic skeleton before aplying weights.
