Hair opacity into real polygon ?
Hey i wanted to know if i can convert the hair with opacity map apilled into real polygon so i can export it and work with it easly, 'cause im working with a daz charachter on cinema4d with arnold as render and when i applies the opacity into my hair it took too long to render (like it's impossible to get a render i let it all night for 9 hours and it render only about 45%) so im wondering if there is any way to convert the hair after i did all the changes needed from hair+opacity-map into real hair polygon, on Daz Studio or C4D, please help me im on my day 3 trying to found a solution
Not that I am aware of, other than using a textured view in C4D to show where to manually cut the layers (and even then the hair is designed to use opacity ot soften the areas in which it is thinning out).
