stylized '21 Character and Hair for Genesis 8 and 8.1 Female broken joints
Hello i think the Product is broken when i pose the Figure the fingers are deforming and when i use a Genesis 8 Pose i have to use the Genesis 3 to 8 Pose correcter or the Arm is not in the right Pose.
For the Problem with the fingers i have discoverd that the joints from the Bones are not in the right postiton but i dont know what issue it is with the Arms not working with Genesis 8 Poses.
  • How did you install, and how did you load the character (I am guess you used the Character preset since the figure name matches)? I can see what is probably happening - the joint centres are not being adjusted to match the new shape - but I don't know why, especially as no one else has reproted the issue which suggests it is not a simple bug in the product.
  • Briareos0815Briareos0815 Posts: 12
    edited August 2021
    I have Installed it Manualy i Try to Delete and Reinstall it.
    After deleting and installing it again i have still the same issue. I Checked the Male one all Joints working correctly.
    Post edited by Briareos0815 on
  • reelyorreelyor Posts: 237
    I have just tried it, both version 8.0 and 8.1 and have no problems. Install was through the Install manager. I tested by appling a pose preset, and by also using the parameter posing sliders on the hands
    Have you tried applying a different pose to see if the pose preset is the problem?
    Otherwise, I might suggest reinstalling with the Install manager.
    Also, I am using Daz 4.15
    edited August 2021
    I have the latest Version from Daz3D.
    No matter what Poses i use i have always the same Problem only the Female one is not working the Male one works Perfect.
    Tested both of them 8.0 and 8.1
    Reisntalling is not working.
    It is the first time that i have a Problem with a Daz3D Product all others worked fine.
    The other 3D Universe Products works perfect.
    Can you guys post a Screenshot with the Parameters from the joints then i can fix it on my own and save it as a New Preset.
    I tryd it already is not perfect but with the correct Numbers i can fix it.
    2560 x 1440 - 1M
    2560 x 1440 - 598K
    Edit->Figure->Rigging->Adjust rigging to shape
  • AscaniaAscania Posts: 1,855
    I confirm. I got it too. Installed with DIM.
    First image is with using the Invisible Chair pose from this year's April First freebie. Second image is just using the Bend transformation on the right hand index finger. Zip file is a pose preset of the same.
    1920 x 1040 - 270K
    1920 x 1040 - 306K
    zip
    zip
    stylised21.zip
    14K
  • Ok im not the only one with this Problem good to read but sry for you Ascania.
    Super thx @PerttiA this worked.
  • Since this does seem to be afecting more than one user please open a support ticket to let Daz know.
    Support ticket filed
  • Thanks
