Poses not loading correctly
Often when I load a pose onto a figure, the resulting pose does not match the intended pose. For example, I loaded the Base 07 pose (flying kick) to Wolfgang 8.1. In the preview of the pose, it shows the figure with his arms up, near shoulder level. However, the resulting pose on Wolfgang is arms down, with his left arm actually behind and colliding with his left leg.
While this is just a demo example, it happens on nearly all of my poses, regardless of whether I turn limits on or off. What do I do to fix this? Thank you.
That is a pose for Genesis 2 Male, Wolgang is Genesis 8 Male - they have different zero poses so a pose for one will not work on another without adjustment
Ok, thank you.
