Two small download issues
SnowSultanSnowSultan Posts: 3,798
Just having a couple of small problems with some recent purchases and hopefully someone can help.
* The texture resource "Dirty Old Walls" gives a "Download Failed" message when trying to install with DIM.
* Where are the individual props in Merlin's Forge located? The installation only shows the two full scene files for me.
Thanks in advance.
  • bytescapesbytescapes Posts: 1,908
    I've had the same problem, and I've filed a detailed ticket with Support asking them to take a look. With luck, they'll sort it out shortly.
  • FishtalesFishtales Posts: 6,217
    I had trouble with dirty old walls but it downloaded fine manually without using DIM.
  • MelanieLMelanieL Posts: 7,765
    Thanks in advance.
    Re: Merlin's Forge - interesting, I can only see the scene files too - I'd not noticed that the individual props weren't there.
    I only installed the DS file not the Poser one - looking at the ReadMe, I think the Poser one contains the individual props (in Runtime-Libraries-Props) with DS materials (in Runtime-Libraries-Pose), so I guess we both need to install that too?
  • jhofflerjhoffler Posts: 39
    I also notice that the DIM info link for Dirty Old Walls goes to Texture Resource - GREENGROWTH (Product ID 18930) instead of the correct Product ID 19111. I have a feeling the author copied over product data for a previous product without updating / inserting all the fields. These lines from the DIM error log might mean that the download destination field in the DIM template is blank:
    WARNING: Error while downloading to file "IM00019111-01_TextureResourceDirtyOldWalls.zip", error setting up download file
    WARNING: Network Error while downloading to file "": Operation canceled
  • Velvet GoblinVelvet Goblin Posts: 532
    Thanks in advance.
    The Poser version does have individual props, so perhaps that's the way to do it.
  • SnowSultanSnowSultan Posts: 3,798
    Yes, installing the Forge Poser files does add all the individual props. I wish the Studio version didn't require all the usual Poser subfolders, but it's fine.
    Installing the Dirty Old Walls manually also works.
    Thanks very much.
