• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Unity Discussion
Daz Environments to Unity - Help! Transforms always get wonky
anewdreamlifeanewdreamlife Posts: 6
August 2021 in Unity Discussion
I was hoping someone could help me with exporting environments from Daz in fbx format (not using the Bridge)
Whenever I export sets from Daz to use in Unity, once I bring them into unity, the placements of all the props are all over the place, never where they should be.
I've tried so many things in the export options trying to make this work, but no matter what, once it's imported to Unity, everything is scattered in the wrong places.
Does anyone know how to fix this?
  • MelamkishMelamkish Posts: 23
    August 2021 edited August 2021
    If you still would like some help with this issue, I would be willing to try.
    Last winter and early spring, after doing a bunch of Unity, Blender, etc updates, I was
    experimenting with environments, landscape and architectural exports from Daz to Unity.
    At the time I was using Unity v2019 since that is what the Daz to Unity Bridge was based
    on. When experimenting, I would export FBX files:
    DAZ FBX Export
    DAZ to Blender, then export FBX from Blender
    DAZ to Unity Bridge.
    DAZ to Hexagon and then to Modo and back
    Depending on the product I was trying to export I would initially see the same issues you
     mentioned, and figure out how to fix them. I seem to remember some of this, but since
    then, I have upgraded to Unity v2020 3.14 because some of the Unity forum members have
    been using the v2019 bridge with v2020. I have been experimenting with animations. My
    modeling program (I use Modo) can animate, and though I have never tried to animate
    before last month using Modo, I have finally figured out what I need to do in order to
    send my own animations back and forth between various programs. Although I still need to
    work on some issues, I was ready to go back to creating my world spaces when I saw your
    post.
    So, what are you trying to send to Unity? Your own, or a Daz product? I ask because I may
    have it. I have over 10,000 products installed and if I have one you are trying to use,
    would make it far easier to help.
    Post edited by Melamkish on August 2021
  • ArtiniArtini Posts: 10,298
    August 2021
    With Daz to Unity bridge, the environments from Daz 3D store works as expected for me.
    The only problem is when instances are used in such environment.
    You need to convert instances to objects, before exporting them.
    I think groups does not export via bridge.
    It would be nice to have some script in Unity to change objects back to instances there.
    I also think, if you could provide a link to evironment from Daz, that you have problem with
    it will be easier to find workaround.
    August 2021
    Artini is correct in that using the bridge can save a lot of headaches. I have seen the issues of groups and instances also.
    One of the reasons I did a lot of experimenting is because some of the DAZ terrain based products were not done for gaming, so hilly, mountainous, or others, don't always have meshes on the edges that go all the way to "Ground Level".  What I was experimenting with was the Unity Terrain Tools (preview version) to create ground at the edges of various landscapes to "fill any holes" in various meshes. I had a large area created and was importing various villages, ruins, etc, not necessarily at the origin, to see how everything would work together. Some times I would send things thru Blender, or to Modo to make changes and would have to use FBX export and import, instead of the using the bridge.
  • danielbui78danielbui78 Posts: 333
    August 2021
    I think the DazToUnreal code branch has support for Lighting and Environments.  I will try to back-port these features to the DazToUnity code branch when I have time.
    Regarding instances, I'll try to automate conversion to objects + external metadata on the Daz side and back to instances on the Unity side.
    One solution for terrain gaps and holes may be to use a "ground" or "terrain" tag in Daz, then automatically convert that tag(s) from Mesh Data to Terrain Data instead of running it through the FbxExporter plugin.
    Helpful References:
    • Unity Terrain API
    • DazToUnreal Environment Github Commit
    Below is an example transfer to Unity with the bridge one of Stonemason sets: https://www.daz3d.com/urban-future-6
    together with Daisy HD: https://www.daz3d.com/daisy-hd-for-genesis-81-female
    and its render in Unity:
    1891 x 1113 - 827K
    1920 x 1080 - 1008K
    Post edited by Artini on August 2021
    August 2021
    And the short video exploring Urban Future 6
    Another example render from Unity - https://www.daz3d.com/the-last-stand
    This environment just transfers fine as is via bridge.
    1920 x 1080 - 893K
    Japanese Alley instances need to be converted to objects, but afterwards exports nicely via bridge.
    https://www.daz3d.com/japanese-alley
    1920 x 1080 - 538K
    August 2021
    Another example video made in Unity with Urban Future 7 - https://www.daz3d.com/urban-future-7
    Stonemason's sets work nicely in Unity.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
