Look at my Hair dissappeared
I went to use the LAMH catalyzer and discovered that it disappeared from the Window> Panes menu. I tried reinstalling the plugin but it still does not appear in the Window> Panes menu. I've provided a screen shot of the menu. I don't know how to get it back.
  • frank0314frank0314 Posts: 14,713
    What version of Daz Studio are you running?
  • Is it listed in Help>About Install Plug-ins? Does catalyser actually have a pane?
  • LindaBLindaB Posts: 190
    Daz Studio 4.15.02
    Yes, it's supposed to have a pane. It was not listed in Help>About Install Plugins.
    I got LAMH to appear! I reinstalled it again, but used the install manager instead of installing it manually. After doing that, the LAMH Catalyzer appeared in the Help>About Install Plugins and I was able to enter the serial # and then after restarting, the LAMH pane was there.
  • CenobiteCenobite Posts: 206
    Do you need to activate some sort of serial key for that catalyzer to work, some products like face transfer unlimited or other plugins like some world builders require serial activation for it to work fully,.
