How to tell how many polys are in a scene/obj?
Wonderland
in The Commons
How can I tell how many polys are in a scene or individual prop/figure? I should probably know this after all this time but I’ve been using DS just for 2D renders.
Window -> Panes -> Scene Info.
Thanks! Are vertices, quads, faces the same thing as polygons? The quads and faces are identical but the vertices are slightly higher. I don’t see anything about polygons. And what is a node? I’m clueless when it actually comes to 3D aspects of this lol!
Vertices are the points that make up polygons. Faces are polygons, and quads are specifically 4-sided polygons. Some things, like dForce, work much better on quads than triangles or n-gons. Nodes are all the selectable things in the scene, so every object, bone within those objects, lights, cameras, etc. Even though bones are selectable, they don't have their own geometry, so if you've selected a bone of a figure rather than the figure itself, it should still give you the information about the figure.
Thanks!
