Moving compressed/zipped files?
SteveM17SteveM17 Posts: 1,061
Downloading frebies has eaten my hard drive space (the C drive that is). Once I've unzipped a freebie so that there's now a zipped file and a file folder with the same name in My Library is it safe to move to a different drive or delete the zipped/compresed file so it's no longer taking up room, or does DS need the zipped file in My Library in order for the prop /freebie to work?
In other words, when I'm loading a prop into DS, does it access or use the compressed/zipped folder or just the unzipped file folder that has the same name?
I hope this question is clear, I'm not good when it comes to messing with files.
  • WilmapWilmap Posts: 2,917
    DS only uses the unzipped contents of the folder.
    You can safely delete the zipped file. I only save the zipped file to an external drive if I want to keep it as it will take up less room.
  • SteveM17SteveM17 Posts: 1,061
    Cheers for the quick reply. That's just the answer I was hoping for.
    Also thanks for making freebie clothes for Genesis, I've been using them quite a bit.
