Layered image editor artifact problem, need help.
Hello,
I'm adding these line tattoos through the Surface tab using the Layered Image Editor. The problem I'm having is these weird pixilated artifacts outside the lines.
I increased the resolution on the tattoo image and tried both transparent png and jpg files but still no luck. Is there a way to fix this. Thanks!
-David
  • margravemargrave Posts: 1,822
    Looks like the antialiasing isn't blending properly. What is your LIE blending mode set to?
  • barbultbarbult Posts: 26,586
    edited July 2021
    Are you using a compressed JPG image for the lines in LIE? Maybe it would work better with lossless PNG.
    Post edited by barbult on
