Adding to Cart…
Do you have any documentation for this product? It does not appear to come with any, and your merchant resource documentation is either strongly out of date, or contains incorrect information. I am having a lot of problems using your products, and your documentation does not help in any way. There is no way to leave any reviews, but some documentation would go a long way in helping your users to use and understand your product.
Hi there!
I found a bug in Shape Shift for Genesis 8 Female.
Some Glute morphs affect some bones too, in particular Glute Depth, Glute Lenght, Glute Up Down and Glute Width.
Didn't try other Shape Shift morphs yet but that's what I found.
Hi. It's not a bug. They are meant to be rigged. At the time product was created, all morphs had to be rigged to be approved.
Oh! I didn't know that.
Maybe I explained badly. What I mean is that moving some of the morphs, some of the bones move and it's pretty strange because the rig changes.
I uploaded a gif there so you can see what happens for example when moving the Glute Lenght morph: https://gfycat.com/closedlastingadouri
Checking. OK I'll have to re-rig those ones...Won't really affect anything but thanks for bringing it to my attention.
A pleasure!
Fun that I noticed it using Diffeomorphic on Blender, after converting the model to rigify I saw the first bone of the tongue very tiny, after that I back to Daz and checked what were happening :D
Hey Zevo, I'll bring this up here as there doesn't seam to be a Body Diversity thread but I think its a similar issue. The petite morph has problems with hips, feet (only noticable with some clothing) and breasts. Would love you too have a look under the hood there too.
Also if that morph could go beyong 100-150% would be good as some women can be VERY short. Any chance of a male version?
Thanks
Hi. You mean the BD Proportions Petite Morph? Can you post an example? CLothes are fitting fine on my side. Regarding a male version, this product was intended to be a female only product.
Updates have been sent to Daz. There were about 19 -20 files that needed to be adjusted.
I'll wait for the update, thank you very much!
Just got the update!
Thank you very much!
NP
I just installed the update via DIM, and I opened Studio, loaded an existing scene, and I got a missing files notification for Shape Shift. Any ideas?
Sorry, Zev0. I couldn't find out what files were missing because the Help/Report notepad thingy was full. I have a CPU render running on that machine now. If no one else is having a problem, I'll have to figure it out on my end.
Well, as far as my situation goes, I have had any issues and I use Shape Shift A LOT. I'd say 90%+ of my figures have Shape Shift morphs applied.
Hi, I bought this individually but I see on the bundle it says that it also works for G8.1. I tried using the product I have for 8.1 but it does not show up. Is the G8.1 compatibility only when purchased as the bundle?
thanks for the great products
Hi. Morphs on G8 appear on G8.1 aswell automatically.
Hi, it isn't showing up automatically. I've posted in several FB Daz groups about this. I will try to add images here, but It is not showing up as an option for G8.1. I have uninstalled and reinstalled and it still doesn't show up for 8.1.
Is your 8.1 installed in the same content library as 8?
I was just having a look at the files and my MyDaz3Library is on my D drive. I had a look at Female 8 vs Female 8.1 and your folder is missing from Female 8.1. Should I just add the folders I'm missing in 8.1 manually? Before looking at the actual folders I did uninstal and reinstall via DIM and that didn't help.
Morphs on G8 automatically appear on G8.1 unless they are specifically blocked by sellers.
The morphs do not have to be copied over to 8.1 data folder.
Morphs found in 8.1 data folder are for 8.1 specific products.
If this product is not showing up on the 8.1 figure then there is something wrong with your figure install. I don't think this issue is product related. Nobody else seems to have this issue.
Lastly please attach a bigger screenshot as I cannot see what is going on in your example.
The screenshot was just showing my limited products that showed up when a 8.1 character was selected. I agree the problem is somewhere with my install or library folders. I went ahead and manually added the folders and everything is showing up correctly now.
Thanks for responding and thanks for your awesome content!
Sweet! Glad it's working for you now, and you're welcome
is it possible to sepperate these morphs from all the other morphs on the shaping page? Some of them are pretty crowded.
Hi. Try using parameters tab instead of shaping.
