Daz Bridge not compatible with Maya 2022
Daz plugin won't active it under Maya 2022 (ok under Maya 2020.4). A date for an update ?
Thanks !
Thanks !
Maya switched to python 3 in 2022, so a lot of plugins are currently broken. Perhaps you could manually switch Maya 2022 to python 2 and see if the plugin still works. I managed to make some plugins work that way:
https://matiascodesal.com/blog/how-to-launch-maya-2022-with-python-2-if-you-are-not-ready-for-python-3/
Keep in mind that support for the Autodesk/C4D bridges is non-existent. Only the Blender bridge gets support. The rest are useless for production work.
okay thank gosh other people have noticed this. Do I have to switch maya to python 2 or is daz going to fix this bug in the next update?
I just ported the script to Maya 2022.
You can get it here: https://github.com/guto88/DazToMaya
how do i get the files? its only codes
i got this error when trying to select "loaded" on the Daztomaya.pu
ERROR file xxxxx pluginwin,me
how do i fix the file?
this is still a problem and idk how to fix it!!
# Error: NameError: file <maya console> line 1: name 'mel' is not defined
now im getting this after replacing the files from
