can't use MDL shaders
I have tried to add Nvidia vMaterials 1.7 to my setup, was not able to do it successfully. Any help would be appreciated. Not sure what I did wrong. The 1.7 libary is not functioning. Trying to render after applying a shader causes Studio to crash ... the Log says, missing assets files.
Post edited by mcorr on
go it figured out
You might want to give the solution in case there are others with the same problem...
