Where Did My Categories Go?
CathyMCathyM Posts: 261
Hi! I really hope someone can help me with this - all along since I started using Daz 4, I set up a complex and yet easy for me to find things set of folders under the Categories tab - and took countless hours going through the confusing jungles of folders in the Poser and Daz categories finding all the clothing, their materials files, the morphs, the textures, the different props and sets and well everything, and then everything related to it, and sorted it all out and put it together in a way that I knew exactly where everything was. This worked great for me until today, when I started Daz 4, and tried to use the Categories folder - which now appears to be empty!
PLEASE tell me that there is some way to get this back. It kind of makes me sick to think that all that work has been somehow erased. I guess if that is the case, I am not going to do it that way, I'll just delete everything and reload it all separately if possible and try to sort it into different runtimes or something. That will cost me a tremendous amount of time, but the way it is now, it's impossible to find anything. Soo hoping there is some sort of answer to the mysterious dissapearance of all my categories folders...
Thanks for any help! -Cathy
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • fixmypcmikefixmypcmike Posts: 19,689
    If Categories is completely empty (not even the Default categories) then either the CMS isn't running or something is blocking it from communicating. Shut down DS4, then go to Start > All Programs > DAZ 3D > DAZ Content Management Service and click on "Start DAZ Content Management Service".
  • CathyMCathyM Posts: 261
    Hi cridgit and fixmypcmike - thanks so much to both of you! Although actually cridgit's post is what got me thinking about what could be the cause - I began reviewing what I could have done that could have had any effect on the "categories" (and also the "products") since neither of these have the real physical files in them and are actually cross-references from what I can understand that Daz set up to organize with if you choose - I use categories because I have a large amount of files under Daz 3 runtime that is not seen by "smart content".
    Anyway, I thought about it and the other night due to lightning storms I had turned off my computer - I usually leave it on. When I tried to restart it in the morning, it wouldn't cycle up, and so was sitting there unresponsive. After waiting over 20 minutes and listening to it struggling to power up, I turned it off. I know that is a bad thing to do, but I figured I was loosing the hard-drive and letting it grind like that might be just as bad as turning it off.
    I waited about 10 minutes and restarted while praying fervently - this time it managed to start up completely, but after giving me the message that windows hadn't been shut down correctly. It didn't occur to me that content manager hadn't been started until I saw your post cridgit and thought about it - turned it on this morning, started up Daz, and ooooh thank you there are my multitudes of categories... I was so depressed thinking I would have to rework the weeks it took setting that all up. So although I had it fixed before reading your post fixmypcmike, you also nailed it as to what was the problem - again thank you both very much!!! I am soooooooo glad I asked here before undertaking the task I had imagined - Uninstalling and reinstalling EVERYTHING. Now I know to check whether that's running or not before panicking! :-)
    -Cathy
    edited May 2022
    Redacted
