Daisy HD for Genesis 8.1 Female conflicts with Daisy for Genesis 8 Female
Hello all, as a FYI,  Daisy HD for Genesis 8.1 Female morphs has conflicts with Daisy for Genesis 8 Female morphs,which in results, DAZ load both Daisy's with deformed imploded bodys. I have sent in a help ticket, but have not received a reply, so I did some investigating in the data folders and noticed that both products contain a Daisy Body.dsf and Daisy Head. dsf. I removed one of the products data files and now Daz loads the other product correctly. There needs to be an update to Daisy HD renaming the morph data files so that users can have both products fully installed. I have not report these findings to Daz yet since they have not replay yet to my open ticket. Also, I understand how this naming problem gets out of hand, especially with 3rd party products, however, this should have been found in Daz quality control.
Daisy HD for Genesis 8.1 Female: https://www.daz3d.com/daisy-hd-for-genesis-81-female
Daisy for Genesis 8 Female: https://www.daz3d.com/daisy-for-genesis-8-female
    Oh, thanks for posting this! Very helpful
  • Rod Wise DriggoRod Wise Driggo Posts: 2,335
    Thanks for the info although I do not own the earlier Daisy. Talking about the new Daisy HD I am not sure whether I still suck with lights and the new 8.1 shader but for me it seems that the gens texture and also the crotch area without gens applied are a bit off. Same with the gens texture for the male AE. Applied the Jada texture for comparison and that one worked far better. Did I mention that Jada's texture is the best for 8.1 by far?
  • CryphiusCryphius Posts: 64
    My problem with Daisy HD is the anatomy mats dont match. Neither the female or male textures match the torso. Theres a very clear line. Can you confirm this happens too?
  • jimmyzpopjimmyzpop Posts: 118
    I agree, Daisy HD texture mapping is all messed up. I can see seams in multiple locations, as well as ,the areas noted above. This is another DAZ quality control issue for this product. Hope some updates happen soon, otherwise I will need to return this product ASAP.
    Ah, so there really is an issue with the textures. Well I already contacted the vendor via PM. No response yet. Maybe someone needs to file a ticket for an update to happen. Pity though as I really like the morphs.
    I put a ticket in for the textures.
  • someone who has this, can you check if the lashes morph are part of the morph? are the head and body morph separate? is the lashes separate? because they seem to deform and go well below the eyelid, which isnt a problem if you can dial it out and use a better lashes morph that doesn't distort the lashes. It's a really cute character- none of the promos show a clear full body with textures so can't comment on seams or not, but the shape looks really well done and the smile gorgeous. I only noticed the weird lashes well below where normal lashes go and that at least is super fixable.
    see the files list:
    - no dedicated lashes morph
    - separate head and body plus hd moprhs
    - morphs are great
    - textures have flaws
    1288 x 968 - 885K
  • PFAPFA Posts: 131
    Hi guys, thank you for the reports I'm currently working to fix these issues. Your feedback is VERY appreciated. heart
  • PFAPFA Posts: 131
    I'm so happy you guys Like Daisy. Fills my heart with Joy !
    If you could, could you send renderers where you see the problems in the textures?
  • PFAPFA Posts: 131
    BTW, I wanted to create a body morph that affected the face and a head morph that has the same level of body weight as genesis 8.1 female so people could use the head with other bodies and not look out of place. However, The quality control did not let me do that for some reason. So i Included in the "Hidden" a slider that makes her face skinner to match the genesis 8.1 female weight so you can you daisy's head with other bodies.
  • PFAPFA Posts: 131
  • xyer0xyer0 Posts: 6,405
    I'll be watching this thread for a fix. I'll have to delay my purchase of Daisy for G8.1 until then, since I own and use Sprite's Daisy.
  • nonesuch00nonesuch00 Posts: 18,826
    she's super
  • PFAPFA Posts: 131
    while I'm working on the issues here is some more potential to use daisy .she can not. not look adorable
  • FrinkkyFrinkky Posts: 388
    edited July 2021
    Daz really needs to assign each PA a prefix the must use on each morph to distinguish them from another PAs. Offsite products could still be an issue, but at least Daz's own products won't.
    Also, the thigh gap for such a robust stature seems extreme - unless that is just the pose (promo). can someone clarify? Thanks.
    Post edited by Frinkky on
  • PFAPFA Posts: 131
    Yes, she does have a thigh gap I made it on purpose as her body was inspired by a real woman (who is my best friend <3) and she has. I wanted to recreate her thicker torso with skinnier legs. Not all plus size women get thicker legs and but. Just wanted to stay away from the stereotypical plus-size proportions so that is why I chose my friend .
    Fair enough - thank you for clarifying.
    She's super adorable indeed :) Please say you'll fix her eyelash morph too?
  • PFAPFA Posts: 131
    Absolutely <3
    Her face definitely is adorable! I don’t have a need for plus size models but I’d love to see a normal model with the thinner version of the face if you do a second version.
  • PFAPFA Posts: 131
    SURE! I had to render 2 really quick because I didn't have any .So here it is.
    Wow! Beautiful!
  • I was gonna pass on Daisy... until I saw your "Thinner" version... ah crap... My Load times hate you!
  • tsroemitsroemi Posts: 3,527
    Hi there, have the problems with this figure been fixed in the meantime? Would love to get her but am also using the other Daisy!
