UltraScenery - Apple Orchard (and others)
JasonWNalley
So, I have most of the UltraScenery stuff available and think it's one of the best tools for creating random and realistic-looking landscapes. However, recently, after I purchased the Apple Orchard and the Stones, I started to have some quirky aspects that maybe have been present the entire time, but I never noticed, or they're new issues.
The most pressing two issues I'm having currently reside with the Apple Orchard specifically.
Issue number 1 is that 2 trees are left unplaced at the origin point, I've moved them (which you will see circled in red in the viewport image) to fill in part of the gaps that exist in the scene (this is issue number two)
Issue number 2 (expanded), The Rows of trees are only partially populated, but the proxies are all there. I've chosen a top view to best illustrate the issues.
My system specs:
Threadripper 3960x
128GB DDR4
Dual RTX 3090
I have already reinstalled all of the ultrascenery products and the "required products" for those, and it still doesn't fix the issue.
Any help you guys can provide would be appreciated
Make sure that not only are all products needed have been installed, but also that the installation method of all 3 (ie DIM, connect, central) is the same, and all were placed in the same runtime.
I am not certain that US works at all if installed with Connect.
Thanks for the speedy reply, but they were all installed using DIM and all are in the same MyDAZ 3D Library that DIM extracts to.
Try asking in one of these two Forums.
https://www.daz3d.com/forums/discussion/408551/ultrascenery-experiments-and-experiences/p1
https://www.daz3d.com/forums/discussion/466351/ultrascenery-new-territory-commercial/p1
