fitting Genesis accessory to Gen2
Hi im having problems with fitting a necklace for Genesis Male unto a Genesis 2 male figure
the necklace in interest is from "Effortless Cool for Gen Male"
im trying to fit the necklace unto Lee-6, and the necklace just distorts
tried with either "unsupported: none" and "Genesis: none"
same results
i tried to use the hidden properties in Parameter tab
but there isn't any property that i can adjust
anyone has an idea? thx!
I'd probably just parent it and manually adjust it rather than using autofit.
i guess, but it will become a hassle when changing poses
i kinda planned to use the character for multiple scenes
Try increasing the scale of the necklace by 5-10%.
Lee is very bumpy.. pretty much anything you put on him that doesn't have a custom made morph just for him is going to do that. Best suggestion would be to use the auto fit but then go into the parameters for the necklace and turn the auto generated Lee morph to zero. (you may need to turn off limits on the dial, and it won't show up unless you have show hidden properties checkmarked) It won't fit perfectly after that but it shouldn't be nearly so distorted and will take your poses like normal.. if you know how to use d-formers you can use those to snug up the fit. Another thing to watch out for with auto converted things like that.. the pectoral bends need to have their weight mapping adjusted quite a bit for necklaces usually, you won't get that with a conversion... so you'll get less distortion if you zero out the pectoral rotations after you apply you body pose.
