Shading Domain, soo confused
i'm making 2 separate shading domains on a cube.
i selected the polys in the left, clicked add, it asks if want to assign current selection to new domain, i click yes
but then when i go to select by domain, nothing
how do you save the selection to the shading domain?
i've done it in the past, dont know if my carrara is broken, or i'm just crazy senile
help, aiuto!
also trying to make both sides cover the same area on the uv grid
  • HeadwaxHeadwax Posts: 10,464
    should work are you doing the drop down ?
    select>select by> select by shading domain
    what happens if you go into she shader room - do you see the nes shader , what happens if you make it red as an example?
    edited July 2021
    yeah, showing diff colors. thanks.
    is weird selecting  by domain not working.  oh well
    trying to finish the hein wizard render.  keep getting stuck.
    uv seems to be working. sort of.  trying to make a corner o f a room out of a cube.  flipped the normals.
    one wall renders ok the other doesnt seem catch any light.  never saw anything like it before
    sized and saved a light with his wizzie staff. saved it to tray.  but the light resizing didn't keep.
    And now carrara is in a state of not responding
    Post edited by Mistara on
    edited July 2021
    hmm
    that's odd
    time for a reboot?
    oddly I had  a character that wouldn't render the other day - whole figure and clothes wouldnt accept any lighting - before that I'd had an error code but I'd saved the file before that - rebooted and fixed it I think
    good luck -
    post in the wip thread if you would like more time - no trouble to extend
    here's a countdown timer as a muck around   https://w2.countingdownto.com/3700154
    Post edited by Headwax on
  • StezzaStezza Posts: 8,919
    yep, you may need a reboot of the PC ..
    works fine over here yes
    I find after a Carrara crash some things don't work as they should when opening it back up until the PC is rebooted. cool
