DAZ 4.15 - Checking full scene by IRAY MEMORY ASSISTANT
Hello guys
I just wanted to render my final picture but I get some errors (black screen)everytime when I turn on NVIDIA IRAY preview... So I guss my PC dosen;t have enough V RAM or SYS Ram to achieve the best goal...
So I tested my scene by SIM TENERO and this are results of his deep scan (as you can see on pictures below). I'm no't an expert from computers so these all numbers are  just blank page to me...
On two last pictures are system requirements of my PC ( I've got Gigabyte GeForce GTX 1060 6GB Video Adapter).
Finally, I just wanted to render only 4 characters with parrrot ( other two pets and two figures I made them invisible - I want to render them in second picture for additional use in photoshop - combine them into one poster). I need a little tip to resolve my render problem (Yes I know my PC is not engouh strong as It's sohuld)and I know that my system requirements will let me redner only pictures not even a small animation...
    edited July 2021
    Yoy have 6GB's of VRAM and SimTenero tells you need 5.2GB's for what you have selected, except, the OS and DS base loads are not taken into account and when rendering IRAY needs "Working Space" of at least 1GB.
    I would estimate, you need to get the VRAM usage reported by the SimTenero down to max. 3GB's, start by taking down the SubD's on the figures, if you are rendering in that scale, you won't see any difference or improvement with higher SubD's, but you are burning VRAM with them.
    Edit, and since you have a GTX card, it needs additional VRAM to emulate the RTX functions in software, how much I don't know since I'm using an RTX card
    Post edited by PerttiA on
  • Richard HaseltineRichard Haseltine Posts: 109,038
    Note that the tool is giving only an extimate, it can't be certain how much memory the actual Iray data will take.
  • Silver DolphinSilver Dolphin Posts: 1,640
    Adam just use the free script convert iray to 3delight shaders and render with cpu. You could also use Blender. Iray needs alot of vram or just have to strip down your scenes.
  • lord Adamlord Adam Posts: 125
    Thank's guys for all help I can getsmiley
    I just used free script and converted all items in my scene to 3delight shaders (as Silver Dolphin sad). Final render (only by CPU) take more than 1 hour (the most of deatials of my picture rendered very quickly but only beard for my grand-pa, a men in black hat - take about half an hour...). I wonder how much time it takes in Nvidia I-Ray but I think that kind of problem would solve a better PC and a lot more VnRAM...
    Hopefully I rendered all chractres in one picture so the main goal was achieved, thanks for any tips, againwink
    1920 x 1080 - 1M
  • charlescharles Posts: 866
    Or you could reduce texture size via compression Render Settings->Advanced> Texture Compression : Medium and High, set high to something lower.
    Or you could render in parts and stitch together in a paint program.
    edited July 2021
    Yes, I heard about that method but never have tested this so far...
    You mean - a final render in Nvidia I-RAY? I got PHOTOSHOP CS 6 64-bit so I could stitch all parts of my pictue there... Is there any quick tutorial for that??
  • juvesatrianijuvesatriani Posts: 561
    Check last reply in this thread https://www.daz3d.com/forums/discussion/comment/6887816/#Comment_6887816  ;
